Initial condition of isotropic turbulence
Old   March 1, 2005, 06:41
Default Initial condition of isotropic turbulence
Ye Jianying
I want to perform direct numerical simulation of isotropic turbulence. But I donot have initial velocity data of turbulence. Do you know initial velocity data which is opened to the public by web, or by something?
Old   June 12, 2012, 13:26
krisshoe is on a distinguished road
This is what I did when I needed an initial condition. Start by running your forced isotropic turbulence code for a very coarse mesh (say 16^3) until you reach some statistically steady state. Then, use this result as an initial condition for a more refined run (say 32^3). Keep working your way up until you reach the resolution you need for your simulated flow. This bootstrapping approach provided me with a more rapid way to get to a statistically steady state than just starting and running a very high resolution case all the way through.
krisshoe is offline   Reply With Quote
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 11:47
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 08:11
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 06:55
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
