February 16, 2005, 21:26 |
Kiva3v2 under RedHat Linux9.0???
Hello everyone:
I am new with RedHat Linux9.0, and Kiva3v2 can not be complied properlly, the problems are: 1. How to specify real type as double precision; 2. when nv is big enough, the program will not be run (PC with 1.0G RAM). Help needed! Thanks in advance. LiQiang |
February 19, 2005, 04:47 |
Re: Kiva3v2 under RedHat Linux9.0???
which compiler do you use. I have not problem in red hat linux 9.0. Can you send me your makefile. Can you show the error which you get. Z
February 19, 2005, 09:50 |
The compiler in ReadHat Linux 9.0 is G77, and in kiva3v2 there is real variable have a big value up to 1.0E+100, and because the variable is defined as real type which has a word length of 32bit by default in G77, so INF is occured. Can you help me with it?? Thanks in advance
February 20, 2005, 03:38 |
For most compilers, the -r8 option will enforce 64-bit reals throughout.
February 21, 2005, 05:14 |
Is it working with Rami's advice. Actually we are working with ifc(version 8) compiler. as far as I know it is free why do not you install it and recompile everything. Z
February 24, 2005, 21:22 |
I have installed the Intel fortran compiler 8.1 on my Linux and it works well. Can you help me on the best set of command option , I do simulation on PC, one processor , 512 RAM and Intel Pentium4
[Netgen] Netgen segfaults tetmeshing on Redhat EL5 | djvictoid | OpenFOAM Meshing & Mesh Conversion | 1 | June 11, 2011 07:53 |
I want to know how to find out the latex in redhat | KK | Main CFD Forum | 4 | July 5, 2007 05:00 |
C++ manual for RedHat 9.0 | Abhijit Tilak | Main CFD Forum | 12 | September 16, 2004 04:44 |
CFX5.6 on Redhat 9 | Jingo | CFX | 5 | July 31, 2003 18:09 |
Setup on Redhat Linux 8.0 / OpenMotif Library | Steve Lewis | Siemens | 3 | April 3, 2003 11:20 |
