April 9, 2011, 18:03 |
How important is clean geometry for CFD?
Vertex Wrangler
Rep Power: 15 |
I am well aware of the importance of a clean topological model when it comes to performing FEA analyses, because the mesher really has a tough time with tiny faces and short edges and other such guck.
Since CFD has more of a grid approach to discretization, does it matter as much if your geometry is clean or not? Does it also 'mesh' the model similar to finite elements or are finite difference/volume methods working entirely different? What about a solution that takes into account heat conduction in solids as well, what about then? |
April 10, 2011, 01:48 |
#2 | |
Raashid Baig
Rep Power: 16 |
April 10, 2011, 09:48 |
Rep Power: 17 |
In my experience having a clean geometry is crucial. Without a clean geometry it is very difficult to obtain a quality mesh without some of the bad things that were mentioned in the post above.
Having those "bad things" can lead to divergence in your simulations, lack of proper convergence or poor results in those areas. |
April 11, 2011, 19:05 |
Dan
Rep Power: 15 |
Bad geometry is a recipe for disaster in every way.
If you have bad geometry, chances are something got messed up somewhere and no one wants to take the time to fix it. It is frustrating, but it has to be done or else you'll shoot yourself trying to debug your mesh and solutions. The question is, why WOULD you begin any type of simulation with corrupt geometry? If it's a time thing, then just be patient and fix it... you'll be better off in the end. |
April 12, 2011, 13:28 |
Vertex Wrangler
Rep Power: 15 |
Glad to hear it, I'm a proponent of clean models myself. Not only for the repercussions a dirty model can have - just seeing nasty topology makes me just go crazy and I want to fix it! Whether it would make any deal or not.
April 13, 2011, 10:48 |
pritish
Rep Power: 15 |
i can tell you...it takes double the time or more to debug a volume mesh....so have it cleaned before that ! ! !
Pritish F1 freak |
April 13, 2011, 10:52 |
#7 | |
Pauli
Rep Power: 17 |
The other option is to throw your hands up & complain the CAD data is unusable. Since your customer likely won't want to recreate the CAD data, you run the risk of losing business to someone who will work through bad CAD data. |
April 13, 2011, 20:44 |
#8 | |
Dan
Rep Power: 15 |
discretization, mesh, topology |
[ICEM] O-grid around wing geometry | Anorky | ANSYS Meshing & Geometry | 15 | November 27, 2017 13:43 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
GAMBIT, CAD import, clean up geometry problem | Nuray Kayakol | FLUENT | 1 | December 30, 2007 11:43 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
