Tf is averaged by static or total temperature ??
Old   April 6, 2011, 22:30
Default Tf is averaged by static or total temperature ??
NPU_conanxie is on a distinguished road
Hi, how are you? I have a question for your help.
Assume compressible idea-gas coolant flows into a heated channel like turbine blade internal channel. BC: walls are given constant heat flux, inlet is given mass flow and total temperature, outlet is given pressure. Now I want to obtain the wall heat transfer coefficient, h=q/(Tw-Tf). where Tw is wall temperature and Tf is the bulk temperature.
Generally the bulk temperature,Tf, is simply averaged by inlet and outlet temperature. Now, I just want to know, do the inlet and outlet temperature be referred to total temperature or static temperature? Or, Tf is averaged by inlet static temperature and outlet total temperature ?
Wall temperature,Tw refer to static temperature? If I choose static, the some of Tw are lower than the Tf.
Please help me charify the problems. Thank you.
NPU_conanxie is offline   Reply With Quote
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 06:56
Total temperature and static temperature rogbrito CFX 1 June 21, 2009 19:37
Static and Total Temperature Tomislav FLUENT 4 December 4, 2006 05:59
The static temperature is higher than total temp devy FLUENT 0 March 27, 2003 21:16
