Setting Pressure outlet boundary for simulation of Radial impeller
Old   April 5, 2011, 09:07
Default Setting Pressure outlet boundary for simulation of Radial impeller
Mukund
Mukund Pondkule is on a distinguished road
Hello Everyone,
I am using a C code for simulation of flow field of an radial impeller. The code is an Finite Volume Solver using Simplex Algorithm. The inlet boundary condition is set as mass flow inlet and outlet is using Neumann boundary condition. I am using Laminar and Incompressible flow,Collocated Grid with the option of doing both steady and unsteady simulations.Presently i am using unsteady simulation and i want to effectually change the outlet Boundary condition so that i have a pressure outlet boundary . so i have tried setting it but the flow field changes and it seems giving wrong results. I have tried working some way out but its seems unfruitful. I hope many among you will have some suggestions.
Thank you.
regards
Mukund Pondkule is offline   Reply With Quote
Old   April 5, 2011, 10:24
YongQiang Chi
sazabi2001 is on a distinguished road
To be honest, I know little about CFD mathematics models. But one thing I learn is, 'open' or 'pressure' kind of outlet may have quite a problem of back flow, convergence and the length of the outlet pipe..
So I gave up thinking so, and put a velocity / flowrate on the outlet, which has an equal amout of flow rate out as the flow rate in... So the model will become like 'blow and suck' pipe thing.
I have not expected any comparison that it will be better or worst in this way, but at least the convergence of the model is not a problem anymore.
sazabi2001 is offline   Reply With Quote
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 17:50
simple model, difficult outlet Eric CFX 7 May 23, 2014 09:13
Static pressure boundary condition at outlet jennz CFX 4 February 11, 2014 04:29
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 11:36
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
