April 3, 2011, 10:18 |
guidance, flapper motion problem
(see repost)
April 3, 2011, 10:34 |
Re-post: guidance, flapper motion problem
Repost: for some reason, my ascii-art picture was getting corrupted. Re-posting now with placeholders "." inserted.\
------------------------ Greetings all -- I'm a professional mechanical engineer, but mostly a mechanisms guy until now. I recently joined a small firm, and it's fallen to me to pursue some questions on a new project involving airflow. So I'm an experienced engineer, but a CFD newbie, and I know better than to reinvent the wheel -- I'd like to gain from the wisdom here. I would appreciate guidance, both the big-picture, *and* nitty gritty details. (I've done some searches on the forums, but feel free to redirect me if my questions are too far back). Here's the deal: Below is an ascii-art side-view of the physical setup. In the picture, let x be the horizontal, and y be the vertical direction, and z be out of the page Our system is quite simple -- think of it as a pipe with a pivoting damper. We have a rectangular tube, with one end sealed (except an inlet slit). and a damper/flapper in the middle, which pivots about a horizontal (z-direction) axis. A relative vacuum is applied at the outlet thus drawing air through the inlet, which is a horizontal slit, located at an arbitrary height. (Symbology below: x = tube wall; \ = flapper; o = flapper pivot; .=placeholder, so that the picture doesn't get corrupted when I post this message) xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx x.........\................................ .<inlet....\............................... x...........o...............--------> flow x............\....................(outlet).. x.............\............................ xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx ^ y | | o--> x z I would like to characterize the movement at the damper, for various flow rates, assuming a low-friction axis. Both with steady-state, and (secondarily) in transient flows. We've noticed instabilities and even oscillations in some mockups, and want to understand the factors governing this motion. So there it is -- Guidance as I get started? (no guidance too basic). What is a suitable software for me to use, best way to approach a problem of this sort... Thanks, --Will Last edited by williaq; April 3, 2011 at 10:52. |
tutorial for solving oscillating cylinder problem | CH | FLUENT | 8 | April 2, 2014 11:56 |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 05:36 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 05:26 |
problem with Mesh motion, please help me! | Giuliano | FLUENT | 2 | November 17, 2006 03:44 |
Dynamic Mesh Problem - please help! | Hila | FLUENT | 0 | August 19, 2006 05:19 |
