Heat Transfer & Boundary Conditions across 2D wall |
February 6, 2005, 14:42 |
Hi; i am facing problems in 2D heat transfer.
In 2D, how to model heat transfer across the wall. what would be the boundary conditions, if convection is taking place on both sides.I dont want to define any fixed temperature on the wall. Through convection, temperature should be defined automatically on the wall. if anyone can help me on this regards; Saad |
February 6, 2005, 22:40 |
Re: Heat Transfer & Boundary Conditions across 2D
any standard text book on heat transfer
February 7, 2005, 09:21 |
I know theoratically what is hapenning across the wall. but i am not able to apply theoratical concepts exactly in fluent. I am facing problems in 'BOUNDARY CONDITIONS".
any input would be appreciated |
February 8, 2005, 06:04 |
Once you have defined the cells that belong to a particular boundary, then apply the b/c of choice.
Fixed flux boundary condition, or alternatively a heat-transfer resistance/temperature combination. Check on your package... you could even go in & alter the user-defined boundary conditions... all depends on the package you are using. diaw... |
February 14, 2005, 05:23 |
1. what is boundary condition? 2. how many boundary condition do we need to specify for a two dimentional heat transfer problem? 3. how is boundary condition on an insulated surface expressed mathematically? 4. what is the one-dimentional transient heat conduction equation for a plane wall with constant thermal conductivity and heat generation in its simplest form, and indicate what each variable represents.
February 15, 2005, 21:09 |
Sounds like you may need to brush up on your basics a little...
Read a few good books... Check out the links page... diaw... |
March 13, 2005, 12:42 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Heat transfer @ wall boundary | AlessandroD | CFX | 0 | August 18, 2009 06:09 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Conjugate heat transfer (vs) periodic boundary | mp | FLUENT | 1 | January 13, 2003 01:38 |
