Boundary conditions for a flame burning with wind
Old   February 3, 2005, 14:22
Default Boundary conditions for a flame burning with wind
David
Hi all,
I am trying to simulate the effect of crosswind on a open combustion flame (vertical flame). The wind entrances the domain by the left side of the domain, so a specifi velocity inlet is assumed as boundary condition in this left side.
However, I don't really know what boundary condition to use for the right side (or wind outlet): I think I have 3 options:
1) Pressure outlet (e.g., pressure known)
2) Outflow (e.g., pressure and velocity unknown?)
3) Negative velocity inlet?
Notice that my domain is only 0.3 m width, and the vertical flame is burning inside that domain.
Any advise would be helpful. Thanks!!
Old   February 3, 2005, 15:39
Default Re: Boundary conditions for a flame burning with w
Runge_Kutta
David,
It sounds like you have a canned code and are limited by the BC menu of the code. If the code is a compressible code, you're looking for a subsonic, nonreflecting outflow BC for gas mixtures. If you have any control, there is one characteristic coming into the domain at the outflow. That quantity must be imposed by you. The boundary permits N_dim + 1 + N_species BCs. For the other BCs,
n dot tau dot t1 = 0
n dot tau dot t2 = 0
n dot q = 0
n dot V_i = 0
or
n dot [n dot (Grad tau)] dot t1 = 0
n dot [n dot (Grad tau)] dot t2 = 0
n dot [n dot (Grad q)] = 0
n dot [n dot (Grad V_i)] = 0
where
q = heat flux vector
tau = viscous stress tensor
V_i = diffusion velocity
n = boundary normal
t1, t2 = boundary tangents
None of your 3 choices are remotely close to what I have suggested.
You could try a subsonic hard inflow. Specify u,v,w,T, and Y_i. Use the last BC to either impose a condition on
(n dot tau dot n = 0) OR (n dot [n dot (Grad tau)] dot n = 0)
or try one of various approaches to specify density (or pressure).
Old   February 4, 2005, 06:59
David
Thanks for the information!
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 08:21
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 10:38
hexagonal boundary conditions s_h Main CFD Forum 0 August 9, 2009 23:15
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
