Defining dynamic zones for Define CG motion
Old   March 21, 2011, 04:51
Default Defining dynamic zones for Define CG motion
Aamer Shahzad
aamer is on a distinguished road
Hello All...
i am using define CG motion macro in dynamic mesh for rigid body sweeping motion of wing in 3D. The grid is O type in 2D and a cylinderical type in 3D. The domain is 15c in the front and back and 5c on the side. Sweeping motion is 0 to pi radians about y axis. BC are as follows
1. Inlet . Velocity inlet (zero velocity given)
2. Outlet. Outflow
3. On +z. Symmetry (as half wing is drawn)
4. On -z . Outflow
5. Default interior. interior
6. Fluid Air (note that the air is still in my case)
presently i am using wing and default interior as rigid body in the dynamic zones and not giving anything to other boundries... i am not getting right results
i want to know that do i have to define other boundary conditions as dynamic zones too ?if yes, then what they have to be defined as (for example stationary, rigid body etc)
aamer is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Correct dynamic zones jpo FLUENT 4 May 1, 2009 11:15
Dynamic Mesh _ Rotational Motion of a Rigid Plate ROOZBEH FLUENT 2 January 30, 2007 01:02
text command for dynamic zones?? greg FLUENT 0 July 20, 2005 11:42
Dynamic meshing: UDF for rigid body Motion Manoj Kumar FLUENT 0 June 20, 2005 02:02
