convergence problem
Old   March 17, 2011, 06:06
Default convergence problem
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
hi.
I have modeled a impingemnet jet for calculating heat transfer rate over a surface and pedestal.
first of all, i run the model in laminar mode without energy activitation.
the flow field generates correctly.
then i activated the viscous and energy mode and heat transfer.*
in another pc i run my problem in turbulent mode and heat tranfer is activated from the beginning of solution.**
in the case * i didnt gain good result for heat transfer.
in the case ** the flow field did not generate after 4500 iteration and alsothe residuals seem to be horizontal and the value of them is very higher than laminar mode..the continuity residual is higher of all.
what is the problem?
the geometry and mesh is the same for two cases.
what is the reason of not generating flow field after 4500 iteration ? why does residuals go horizontal in a high value
morteza08 is offline   Reply With Quote
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
