Differential eq.
Old   January 28, 2005, 05:25
Default Differential eq.
Viktor Bessonov
Would u be so kind to help a stupid student.How to solve the deff.eq.:
y(t)''+A*y(t)'-B*sin(t)=0 Boundary codition you can envent yourself
Old   January 28, 2005, 06:45
Default Re: Differential eq.
pkm
(Book) Differential & Integral Calculus by Piskunov.
Old   January 28, 2005, 07:03
Viktor Bessonov
Thanks,but I've got no possibility to take this book,I'm in Magdeburg,Germany,and there's no library in my company
Old   January 28, 2005, 07:57
ulysses
y(t) = C*exp(-sqrt(-A)*t) + D*exp(sqrt(-A)*t)
+ B*sin(t)/(A-1)
of course if A<0 and A=/=1
C & D can be found using the initial conditions
Old   January 28, 2005, 08:23
Viktor Bessonov
thanks
Old   January 28, 2005, 09:26
Tom
The solution is, give or take a slip in the algebra,
t = C + D.exp(-At) + E.sin(t) + F.cos(t)
where C & D are constants fixed by the initial condition and
E= B/(1+A^2), F = AB/(1+A^2)
Old   January 28, 2005, 09:47
Viktor Bessonov
Ok thanks,at last everything is OK,but how to find C1,C2 out of initial conditions?I've forgoten
Old   January 28, 2005, 09:51
Viktor Bessonov
for examople y(0)'=1,y''(0)=1
Old   January 28, 2005, 09:57
Tom
You have, at t=0 values of y and y', write down the formulas for y and y' at t=0 and solve the equations. In your case D is determined trivially from the condition on y' substitute this into the condition for y to determine C.
Old   January 28, 2005, 10:12
Viktor Bessonov
Thanks in advance,I got the disired.
Old   January 28, 2005, 10:20
  #11
Viktor Bessonov
And how will be looking this eq. if I change it from the second order dif.eq. to a system of two eq. of first order?
dy(1)=y(2)
dy(2)=-A*y(2)+B*sin(t)???
Old   January 28, 2005, 10:39
  #12
ulysses
you're going to apply Runge Kutta methods , aren't you ?
so you set y=z' and if Y = [ y , z] is the vector solution, you have then the system
Y'= [ z , z' ]
or in other way
z = y' z'= y'' = -A*y + B sin(t)
Am I right ?
Old   January 28, 2005, 11:01
  #13
Viktor Bessonov
I hope so,and what will happened with sin(t),should we take the derivative also,tha -> cost???Am I right?
Old   January 31, 2005, 04:59
  #14
ulysses
well once you have Y' = F(Y,T) with F(Y,t) the vector function : F(Y,t)= [ y' ; -A*y + B*sin(t)]
if you discretize with Euler method (for the sake of simplicity) :
Y_n+1 = Y_n + Dt*F(Y_n,t) with initial values Y_0= [ y(t=0) ; z(t=0)=y'(t=0) ]
So you needn't to calculate any more derivatives.
hope I'm right
Old   January 31, 2005, 05:21
  #15
Viktor Bessonov
Thanks a lot for ur help!
Differential Pressure Monitoring CFD User FLUENT 0 October 16, 2008 21:53
differential pressure UDF Phil Main CFD Forum 1 August 20, 2004 11:10
Enthalpy variance with differential stres model Seok-Ki Choi CFX 0 March 30, 2003 21:51
Expression of 2ndary differential equation term J.W.Ryu FLUENT 0 June 18, 2002 00:50
Wallmodel for differential stress model (CFX4 Jan Rusås CFX 4 June 9, 2001 09:58
