Convergence Question
Old   March 14, 2011, 15:59
Default Convergence Question
Ryan
racerdude777 is on a distinguished road
I am running an alpha sweep on a serrated leading edge wing (top view attached entitled "Wing"). Basically setting the wing at varying angles of attack with respect to the free stream in order to obtain lift and drag coefficients. However the simulation was having trouble converging at a low value and i'm wondering if anybody can comment on why this is and/or how to ensure it converges lower.
The simulation is run at a Reynold's Number of 3 million and the number of cells are listed on each picture with the Spalart-Allmaras as my turbulence model. You can see that as cell density increases, some of the residuals smooth out but they don't drop more than three orders of magnitude. The flow domain, as shown in "Slide1" is divided into a higher density region (Body#1) surrounding the Wing and a lower density region (Body#2) in the outer region.
This simulation is in Star-CCM+ but i'm hoping this question about residuals and convergence is generic enough to apply to CFD as a whole. I would also like to avoid playing with under-relaxation values in order to ensure accuracy.
racerdude777 is offline   Reply With Quote
Old   March 14, 2011, 21:54
Martin Hegedus
Martin Hegedus is on a distinguished road
Where is your maximum residual error occurring?
Martin Hegedus is offline   Reply With Quote
Old   March 14, 2011, 23:07
Raashid Baig
cfd_newbie is on a distinguished road
There is no fixed way for saying weather a simulation (based on residual fall) is converged or not, it's dependent on the problem, grid and solver too. But if your residuals are swingeing then you should consider creating a better mesh for your problem. Also you should look at is weather your quantity of interest is converging or not (ex. C_L or C_D)
cfd_newbie is offline   Reply With Quote
Convergence Question James FLUENT 2 October 29, 2005 15:59
Question about convergence criteria? Thomas FLUENT 7 April 8, 2005 20:38
help! cyclone convergence question Lcw FLUENT 1 January 26, 2005 16:29
Convergence to 0.001? Sheng Main CFD Forum 20 March 28, 2000 11:09
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 14:43
