Can someone explain the Y plus value
Like Tree76Likes
Old   June 25, 2016, 05:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
if you need to evaluate heat transfer at the wall how can you say that you are not interested in the physics near the wall? Heat transfer at the wall depends on both the thermal and dynamical boundary layer
FMDenaro is offline   Reply With Quote
Old   June 25, 2016, 05:54
Saurav Chakraborty
srv1406 is on a distinguished road
Thanks for the quick reply. Yes you are right. I misframed my statement. I do have to get proper behaviour of the momentum boundary layer as well in order to capture the thermal boundary layer. It is just that momentum B.L is not directly of my interest. Actually i am carrying out a heat transfer problem in a combustion furnace, which is near rectangular in shape, with air-fuel mixture coming into the furnace from small circular burners. And my purpose is to find the resutant heat transfer at some of the surfaces. Can you plese let me know about my query now ?
srv1406 is offline   Reply With Quote
Old   June 25, 2016, 06:01
Honestly, I doubt you can accurately solve a heat transfer problem at walls without a necessary grid resolution for the boundary layers...Assume you have a decoupled problem, after you solve first the velocity field how can you accurately predict the heat transfer without any information for the velocity near the wall?
In other words, if you disregard the physics near the wall for the momentum, I consider you should simply disregard the details of the heat transfer at the wall (in some sense you have the counterpart of the wall model for the heat transfer)
Old   June 25, 2016, 06:12
Saurav Chakraborty
Yes, the standard wall function also takes care for the solution of thermal boundary layer in the log-law region , just like for the momentum boundary layer. So that seems to work fine to help reduce grid resolution. But what I am worried about is that there must be some higher limit of yplus to which the wall function works. I want to know this limit of yplus.
Old   June 25, 2016, 06:35
I would only consider the model for y+<100
https://upload.wikimedia.org/wikiped...glish).svg.png
Old   June 25, 2016, 07:27
Saurav Chakraborty
Yes, from that figure it does look like it would not be good to consider yplus more than 100, because wall function models upto the log law layer. Actually the departure from log layer and beginning of the outer layer depends on Re or more precisely the adverse pressure gradient. Higher it is, the outer layer begins sooner. It can be seen from a plot in the source mentioned below as well. For zero gradient (flat plate) or favourable pressure gradient, the log layer extends upto yplus of 1000, and the outer layer starts beyond that. But again, yes, a maximum value of 100 would be in the safer side.
https://www.euhit.org/infrastructure...nel/facilities
Old   September 17, 2019, 04:12
Default y+, y* and "Law of the Wall" - a comprehensive explanation
  #27
Tomer
Avr.Tomer is on a distinguished road
Y+, Y* and Law of the Wall: https://cfdisraelblog.wordpress.com/...w-of-the-wall/
Avr.Tomer is offline   Reply With Quote
Old   February 9, 2020, 06:21
Default estimation y +
  #28
adam
medguedem is on a distinguished road
I am a doctoral student at the university. currently I imply CFD modeling in fluent. I spent a year in the mesh , could you help me to choose the best mesh for (y plus) and (dy first cell no mesh) for a turbulent simulation with number of Re = 6000 to 100000 to calculate the constant (B) of the log law logaritmic profile.
Vx / (V *) = 2.5Ln (y / k) + B.
with roughness effect artificial
1. Please explain to me how chosen y +, how chosen turbulence model (k epsilon , k-w, scalable or enhanced RNG or standart ....)
2. Can i use the same mesh to calculate the shear stress and the logarithmic profile and constant B.
medguedem is offline   Reply With Quote
Old   February 9, 2020, 07:05
Why do you not discuss these issues with your tutor(s)? You need to learn not simply to do ...
Old   February 9, 2020, 07:40
adam
if you have an answer tell me if not i don't need any recommendations
Old   February 9, 2020, 07:52
The answer is to study. This forum cannot substitute the role of the tutor of a PhD student. A lot of people think that they can write private email for any kind of help as well as they ask for somehow homework.
You do not need recomendation? Well, the answers is that I have some answers but I do not teach here.
sbaffini likes this.
Old   February 9, 2020, 09:03
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Wow, Captain Politeness here, you are going to have a lot of help, especially considering that you also hijacked the thread
FMDenaro and LuckyTran like this.
sbaffini is offline   Reply With Quote
Old   April 8, 2020, 06:58
Default y+ in condensing flow
  #33
Edgaras
e.smigelskis is on a distinguished road
Send a message via Skype™ to e.smigelskis
Hello everyone,
I am trying to model two-phase upstream flow inside the tube with condensation (film flowing down).
For my understanding there are two regions of shear stress that are of interest: wall - liquid and liquid film surface - 2ph flow.
In this case should I calculate two boundary layers, one considering liquid film velocity and another one considering 2ph flow velocity? Also, the thickens of the liquid film is to be evaluated during simulations, so second boundary layer (l. film surface - 2ph flow) location is not known.
What kind of approach would you suggest? Also, any references to helpful material would be appreciated.
(I am relative new in CFD and planning of using ANSYS CFX)
Thank you in advance.
e.smigelskis is offline   Reply With Quote
Please explain steady turbulence for simpleFoam smillion OpenFOAM 10 September 8, 2010 00:14
Please explain this commands. sri31049 FLUENT 3 March 20, 2009 05:38
Please explain some basic doubts jaswi OpenFOAM 0 September 13, 2007 09:37
Please explain Abby CFX 1 April 25, 2006 07:18
could you explain a everyday life phenomenon? askquestion Main CFD Forum 1 March 9, 2004 14:36
