March 14, 2011, 05:08 |
pipe flow with noozle - ? on BC's
mediode
Rep Power: 17 |
Hello Forum!
Maybe simple, but I am not sure about the following .... I am currently dealing with the attached geometry, a pipe system with known velocity at the inlet. The pipe finally end in an reservois with a liquid with known level, which corresponds to a known static pressure if I only consider the pipe (not the reservoir) in my calculations. At the top, geometrically above the reservoir, the pipe has a noozle where the liquid can drop out. I want to know the quantity of liquid that leaves the pipe through the nozzle. My prob: Which pressure-BC has to be choosen at the noozle? Simply p=0 or have I to refer to the static pressure at the end of the pipe and consequently to the bath level in the reservoir? Your comments are appreciated! m* |
March 14, 2011, 05:57 |
#2 | |
Raashid Baig
Rep Power: 16 |
I think the pressure at the nozzle exit should be atmospheric pressure (Adjusted according to the reference pressure that you have taken for your working fluid) and it has nothing to do what pressures you have specified at the pipe ends. Raashid |
March 14, 2011, 10:31 |
mediode
Rep Power: 17 |
Thank you for your suggestion!
At present I think it is of of major importance if gravity is regarded or not. I'm intending to use a solver that doesn't. If NO velocity-BC would be applied, flow would develop from the reservoir to the nozzle in a case with p=rho*g*h at the reservoir and p=0 at the nozzle. As a consequence p=0 at the outlet AND the nozzle would be the right pressure BC, or? m* |
pipe flow, pressure bc |
Problems with Cyclic & init. BCs for turbulent (k-eps) pipe flow | florian_krause | OpenFOAM | 3 | December 1, 2012 04:11 |
help with compressible flow BC's (need subsonic flow) | meangreen | Main CFD Forum | 5 | July 24, 2010 13:16 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
Reverse Flow at Rotating Pipe Outlet | vismech | STAR-CCM+ | 1 | August 11, 2009 10:38 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
