Could vorticity magnitude be ploted ?
Old   January 24, 2005, 00:46
Default Could vorticity magnitude be ploted ?
w0er
wx = dw/dy - dv/dz wy = du/dz - dw/dx wz = dv/dx - du/dy
w = wx(i) + wy(j) + wz(k)
vorticity magnitude = sqrt(w.w) = sqrt( wx*wx +wy*wy +wz*wz
but how could i define the function into CFD post template?eg:CFX5-POST,FIELD-ViEW,CFD-View
Old   January 25, 2005, 18:34
Default Re: Could vorticity magnitude be ploted ?
Tosh
If you do not know how to add variables for the format used in those softwares, the easiest way is to replace one of the existing variables (e.g. temperature or pressure) with that of the vorticity magnitude.
Tosh
Old   January 26, 2005, 13:28
E Buchanan
Click on create variable then type in the following expressions
Vort X = 0.5*(Velocity v.Gradient Z-Velocity w.Gradient Y) Vort Y = 0.5*(Velocity w.Gradient X-Velocity u.Gradient Z) Vort Z = 0.5*(Velocity u.Gradient Y-Velocity v.Gradient X)
Vorticity = sqrt(Vort X^2+Vort Y^2+Vort Z^2)
Old   January 28, 2005, 01:09
w0er
Thank you very much
Old   February 8, 2005, 08:49
CFD-junior
Hi
The variable doesn't work. I've tried that.
I'm trying to create helical density which is the dot product of the velocity vector and vorticity. could someone please help. I want to know how to enter it in the expression block in CFD-View
Vorticity magnitude CFD-junior Main CFD Forum 10 October 8, 2021 04:42
Vorticity magnitude makaero FLUENT 0 May 25, 2011 21:30
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
magnitude of vorticity using fluent ryan Main CFD Forum 1 November 30, 2009 17:29
Vorticity magnitude Hernani Siemens 2 August 20, 2001 10:48
