How to run parallel in ICEM_CFD?
Old   January 22, 2005, 05:11
Default How to run parallel in ICEM_CFD?
Kiddo
Hi , I can run solver parallel in CFX-5.7.1, and I'm wondering if it's possible to run parallel while meshing in ICEM_CFD5.1 ? Thanks!
Old   January 24, 2005, 05:10
Default Re: How to run parallel in ICEM_CFD?
Roe
If you have a dual processor machine you can run the mesher locally parallel. Go to Settings->General and set number of processors to 2. You can't run the mesher as a distributed parallel process.
Old   January 24, 2005, 09:53
Kiddo
Thanks for your response!
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 15:43
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 14:37
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 09:33
Parallel run diverges, serial does not SammyB OpenFOAM Running, Solving & CFD 1 May 10, 2009 04:28
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 07:33
