Inviscid flow over a forward/backward facing step
Old   January 19, 2005, 13:44
Default Inviscid flow over a forward/backward facing step
Abhijit Tilak
Hi all,
I am looking for test cases for compressible inviscid sonic/supersonic/transonic flow over a backward or forward facing step. Any references (papers/web) welcome.
Thanks
Abhijit Tilak
Old   January 19, 2005, 14:26
Default Re: Inviscid flow over a forward/backward facing s
noName
None of these are inviscid, but they might serve as a good starting point for finding the data you need. Check the references / lit review in these papers:
DNS: LE, H. AND MOIN, P. 1994 Direct numerical simulation of turbulent flow over a backward facing step, Technical Report No. TF-58, Department of Mechanical Engineering, Stanford University.
Experiment: JOVIC, S. & DRIVER, D. 1994 Backward-facing Step Measurements at Low Reynolds Number, Re_h=5000. NASA Tech Memo 108807.
JOVIC, S. & DRIVER, D. 1995 Reynolds Number Effect on the Skin Friction in Separated Flows Behind a Backward-facing Step. Exper. Fluids 18, 464.
DRIVER, D.M. & SEEGMILLER, H.L. 1985 Features of a Reattaching Turbulent Shear Layer in Divergent Channel Flow. AIAA J. 23, 163.
Old   January 21, 2005, 10:49
Abhijit Tilak
Thanks, I found the test cases on some website.
Abhijit
Old   February 16, 2005, 10:18
bouahmed
thank you
Inviscid flow solver luca_g OpenFOAM Running, Solving & CFD 3 August 11, 2024 11:52
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Convergence for inviscid flow over sylinder Rjakk Main CFD Forum 2 March 21, 2007 11:53
Inviscid flow Atit Koonsrisuk CFX 12 January 2, 2003 13:40
backward facing step problem Yung-Ming Chen Main CFD Forum 3 May 11, 1999 23:04
