CFD study for a MAV(Micro Air Vehicle)
Old   May 25, 1999, 12:35
Default CFD study for a MAV(Micro Air Vehicle)
raj
Hi everybody,
please help me out in the following. Which is the Best computational method that can be used to study the performance of a aerofoil of a Micro Air Vehicle of 1 inch chord and 2 inch span considering the three dimensional efects predominant.
Also how to study the performance of the aerofoil experimentally taking into consideration the 3D effects and the accuracy of the measurements.
Old   May 25, 1999, 14:20
Default Re: CFD study for a MAV(Micro Air Vehicle)
John C. Chien
(1). You need to define your Problem Reynolds number first. This will tell you whether the flow over the airfoil is in the laminar or turbulent regime. You can then take from there to determine what method you need. (2). There are books on wind tunnel testing. Go check out the book from a library. This will tell you how to conduct the experiment.
Old   May 25, 1999, 23:05
Ji
Hi raj,
I think that flow around your MAV is still macro-scale, not a micro-flow, so a lot of commercial software canbe used for your purpose.
As for experiments, PIV and Laser mometer could be suitable.
Ji
Old   June 14, 1999, 21:29
Jongtae Kim
I would like to read some papers about numerical and experimental study for MAV. Could anyone give me the lists of the papers? Thank you
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
CFD for air flow analysis in a room bidalufias Main CFD Forum 1 May 12, 2011 20:11
Automotive Air Bag CFD ramboy Main CFD Forum 7 February 27, 2008 15:33
Can CFD help solve air bubble problem? Tim Luxon Main CFD Forum 2 November 16, 2000 12:02
CFD study in combustion L. Li Main CFD Forum 8 August 29, 2000 09:33
