turbulence generator @ Inlet for LES
Old   February 17, 2011, 11:40
Default turbulence generator @ Inlet for LES
SM
canopus is on a distinguished road
Hello
I have mean velocity and turbulent kinetic energy profiles
from experimental data. I want to use this as an input to
my FORTRAN LES code.
Can you please suggest(hints/literature) what are the simple methods to generate a fluctuating field at inlet using the data above?
I have tried random fluctuations based on random number generator
but they do not seem satisfactory.
Best regards
SM
canopus is offline   Reply With Quote
Old   April 28, 2011, 17:54
Default hi
mehdi farahnak
farahnak.mehdi is on a distinguished road
hello every one.
i want to model a isotropic turbulent flow with openfoam.
my case is a turbulence generator in a wind tunnel.
i just know the velocity of air at entrance of the tunnel
i want to model it with simplefoam.
what boundary condition must i choose for P and U and ....?
please help me
farahnak.mehdi is offline   Reply With Quote
Old   December 7, 2016, 10:53
Andrea Fregni
AndreaF is on a distinguished road
Hi Canopus,
Did you find any solution to your problem? I'm facing the same issue for a DNS simulation.
Thanks in advance,
Andrea
AndreaF is offline   Reply With Quote
Old   December 7, 2016, 11:29
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
It's been a while since the last time I went trough LES/DNS literature, but the following are good starting points:
http://www.sciencedirect.com/science...45793009001601
http://www.annualreviews.org/doi/abs...rnalCode=fluid
http://www.sciencedirect.com/science...21999112006389
Edit: the last link points to the method that, in my opinion, is the most simple, and yet powerful, to use. Even if i didn't implement it myself, the unique issue I can see for the implementation is to have a coherent (i.e., shared) pool of random numbers among the different processors fixing the inlet.
sbaffini is offline   Reply With Quote
Old   December 7, 2016, 13:19
Andrea Fregni
Thanks a lot Paolo!
I will have a look to the articles and try to find a solution suitable for a Fortran90 implementation.
Regards,
Andrea
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 07:52
Has anyone successfully used transition modelling? Chebeba CFX 15 May 19, 2006 15:21
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
