Numerical Weather Modelling : Time and space resolution issues
Old   February 15, 2011, 22:32
Question Numerical Weather Modelling : Time and space resolution issues
Christophe Sibuet Watters
chriswatt is on a distinguished road
Although I am experienced with CFD and numerical modelling of fluid flow, I have some difficulties to solve the following question :
My problem is the following : I wonder down to which time resolution, the solution provided by a numerical weather prediction (NWP) model can be considerred to be realistic and physical, providing the typical hypotheses involved within operational NWP models. For example, let say I can measure the wind at a given place. On a minute to minute basis, I can observe the wind to vary. These variations come from turbulence (mechanical and thermal) and from the large-scale weather motion. Of course, in a numerical solution, variations of the wind component also exist, but what is the limit down wich these variations are purely numerical, and have nothing to see with reality ?
What would be the limit in time below which timestepped solutions should not be kept, and only time averages should be considerred instead ?
The typical hypotheses used in NWP models are :
- Treatment of small scale turbulence by turbulence closure of zero-order (mixing-length type treatments)
- Treatment of larger scale turbulence id. LES models ; NWP models respect CFL conditions. For example, a 15 km resolution model will use a Dt of 45s.
I imagine the response is a function of the spatial and time resolution of the NWP model, and probably of local wind velocity... but I can not figure it out on my own, since most of the problems I have studied in the past are steady over time !!! any advice or thought on the subject is very welcome !
Chris
chriswatt is offline   Reply With Quote
numerical weather
Variable BC in time and space for transient run Porry CFX 2 February 21, 2012 10:38
Richardson Extrapolation to check time and space convergence Hooman Main CFD Forum 0 December 29, 2010 09:19
Time and Space Derivatives. beezee99 FLUENT 0 August 19, 2010 02:34
Space and time discretization of Euler equation Hooman Main CFD Forum 2 June 6, 2010 09:30
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
