Finite volume or finite differene for free surface |
January 1, 2005, 11:20 |
Happy New Year,everybody:
I want to simulate falling liquid film using CFD codes. Does anybody know some codes using Finite Volume Method(FVM), together with moving boundary(MB) and free surface(FS)? maybe can tell me some methods Thanks for attention ! |
January 2, 2005, 07:56 |
Re: Finite volume or finite differene for free sur
Did you have a go with Fluent |
January 3, 2005, 00:27 |
http://www.vug.uni-duisburg.de/MOUSE/
Hi, If you know C++, you can download mouse. They have implemted level-set method for free surface flow. Only thing is that you need to implement turbulence models into it. Try level-set search in google you can get the refernces. Good Luck and Happy New Year Apurva Shukla |
January 3, 2005, 00:46 |
thanks for help. but I just want to write codes in Fortran90, unlike using software
thanks for help. but I just want to write codes in Fortran90, and need some examples about free surface flow....
January 3, 2005, 01:23 |
http://asme.pinetec.com/fedsm2000/data/f-233/11257.html
Hope you can get this paper. Till now I have not found any example on free surface flow. Regards Apurva |
January 4, 2005, 13:35 |
I'm doing research on free surface flow. I have a short paper as shown below: " X.Xie and M. Pasquali, Computing 3-D free surface viscoelastic flows, in A.A. Mammoli and C.A. Brebbia, editors, Moving Boundaries VII: Computational Modeling of Free and Moving Boundary Problems, pages 225-234, Southampton, UK, 2003. WIT Press. "
I think you can find many examples in the book. By the way, it really takes time to write code starting from scratch. If I were you, I would take A.S. Sun's suggest to start from some existed code and modify it to what you want. |
January 7, 2005, 12:23 |
There are some papers by Prof. Peric by both the methods using ALE(moving grids) and VOF
One I am writing down here.. Computation of free-surface flows using interface-tracking and interface-capturing methods By Samir Muzaferija and Milovan Peric Chapter 2 in O.Mahrenholtz and M.Markiewicz(eds.) Nonlinear Water Wave Interaction, Computational Mechanics Publications 1998 |
January 10, 2005, 08:42 |
#9 |
in our library,there has not the book!
which site can download the online book? |
Finite Volume Method | cfd seeker | Main CFD Forum | 3 | September 8, 2011 05:36 |
Finite Difference Vs. Finite Volume | elankov | Main CFD Forum | 43 | December 18, 2010 17:30 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Flux calculation in vertex-centered finite volume. | Martin | Main CFD Forum | 3 | June 4, 2008 11:04 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
