Samanjoy Barua
Rep Power: 0 ![]() |
I am using vof method to analyzing of liquid thin film, When i am using two phase flow, unsteady, and implicit body force. When simulation running its showing reverse flow in diffferent phases. I am confused i am correct way or not. any body can help me pls. My 2d model geometry is 40mm inclined plate, geometry made in Gambit, where two phase liquid and Gas which are flowing parallel flow, Boundary condition are liquid inlet( velocity inlet) gas inlet (pressure inlet), mass flow(Pressure Outlet) I have considered low Reynolds number, Surface Tension, Gravitational force. Is there any which I have to consider, and any necessary information please give details. I dont want to heat transfer effect. thank you very much Saman Last edited by Saman; February 11, 2011 at 18:41. |
#3 | |
wan zhihua
Rep Power: 8 ![]() |
#4 | |
wan zhihua
Uwe Pilz
Rep Power: 15 ![]() |
I recommen:
- simplify your case to the point where it ist simplest but shows your isue. - after allclear zip the case and store it togehther with some explaining pictures at an internet store - link it here.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
combustion flow simulation in liquid rocket thrust chamber | geetha sri | FLUENT | 1 | February 4, 2016 17:04 |
Turbine film cooling simulation | Lorenzo | CFX | 1 | September 9, 2010 12:13 |
can FLUENT simulate the liquid film thickness | fadhil | FLUENT | 1 | March 11, 2009 06:48 |
Wall Film modelling | Computational Dynamics | Siemens | 0 | May 11, 2001 06:52 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
