How to calculation TKE in LES
Old   February 9, 2011, 14:55
Question How to calculation TKE in LES
Tian Zhou
lizzy0zhou is on a distinguished road
Hi Dear,
I'm a real newbie in CFDs. My questions might be very stupid:
1. How to calculate the velocity fluctuations (u', v', and w') based on velocities (u, v, and w)? I know u'=u-u_bar, but what does the u_bar represent? Is that time averaged? How to calculate the u_bar?
2. What should I do if I wanna compute the tke from a LES simulation results conducted by Flow3D? Find the velocity fluctuations and then calculate the tke based on tke=0.5(u'^2+v'^2+w'^2)?
Thanks!!
lizzy0zhou is offline   Reply With Quote
Old   February 9, 2011, 19:45
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Indeed u_bar is the time-average of u at the point of interest. A couple of additional comments:
1) You need to start the time averaging after the establishment of the flow patterns;
2) You need to average for a time long enough to capture the mean flow velocity appropriately;
3) I would strongly recommend that you check the time independence of u_bar - either by selecting a different time period for the averaging (best) or doubling the length of the averaging period.
Best of luck, Julien
julien.decharentenay is offline   Reply With Quote
Old   February 10, 2011, 00:28
Tian Zhou
Thank you so much man. And I have an additional concern about the tke. Seems like the velocity fluctuation (u') would be very small (and not stable) compare to the average velocity (u_bar) when time goes to infinity. However, the tke value given by Flow3D looks big (about 7-10% of average velocity) and stable. Can you help me to understand this?
Old   February 10, 2011, 19:09
Hi Tian,
I am not sure what you are referring to as "not stable".
The tke values given by Flow3D are likely to be time average: tke = 1/2*sum_N(u'^2 + v'^2 + w^2), where N is the number of sample (time-step). There is a formulation to calculate u_bar and tke on the fly (or at least an approximation of it).
Comparing the ratio u'/u_bar or sqrt(tke)/u_bar is equivalent to comparing a unsteady and a time average quantities. The ratio values will depend on the particular case under investigation, how the time averaging was done (particularly if the time averaging was started before the establishment of the unsteady solution).
Old   February 11, 2011, 14:05
Tian Zhou
Thank you Julien!I think I have better sense about this now.
fluctuation velocity, les, tke
Pressure coefficient calculation in LES azar99 Main CFD Forum 0 December 13, 2010 22:28
How initialize calculation using LES approach tumble FLUENT 2 June 17, 2010 08:16
problems with a LES incompressible calculation (pisoFoam) laurencep OpenFOAM 2 April 22, 2010 05:53
why in the les calculation, need turbul intensity? aiya FLUENT 0 June 27, 2006 13:30
Warning 097- AB Siemens 6 November 15, 2004 05:41
