June 2, 2009, 09:04 |
wind rotor
#21 |
your wind velocity how much? I think your inlet boundary conditions wrong,out let you given in pressure @ 0 pa know.
sivaramakrihnaiah |
June 2, 2009, 09:18 |
#22 |
setup of Angular velocity,
I think to use this formulation for angular velocity ω that must be applied to moving/sliding mesh (that is to the blades) by an user defined function. ω t = ωt-1 + [Maer t-1 - M res (ωt-1)] / Irotor * Δt where: Maer= torque calculated on rotor due to flow Mres(ω) = function for torque due to electrical energy power generation depending on ω itself. Irotor = rotor Inertia
sivaramakrihnaiah |
June 2, 2009, 10:53 |
Rotor analysis using CFX
#23 | |
I have considered no wind velocity. Fluid domain is chosen as rotating one with 1500 rpm and reference pressure is taken as 1 atm(which is default value). |
June 3, 2009, 04:56 |
#24 |
In NASA WHICH TYPE OF BETTER AIRFOILS
sivaramakrihnaiah |
June 3, 2009, 05:59 |
#25 |
June 4, 2009, 07:58 |
2d wind rotor profile
#26 |
Hi all,
please verify this file, i am sending ram.10 zip file. In this site limit of capacity is there,please any body give me MAIL ID
sivaramakrihnaiah Last edited by sivarama1; June 4, 2009 at 08:49. |
June 4, 2009, 08:38 |
2d wind airfoil
#27 |
Another doubt,
I am analyzing wind rotor blade airfoil,i am attaching file please check it out, wind velocity means free streem velocity 50m/s,atmospheric conditions, angle of attack 4 dec, but is converging,results drag and lift coefficents very very high is comming,i think i given boubdary conditions wrong, please check it out and let me know Thankyou.
sivaramakrihnaiah |
June 4, 2009, 08:47 |
#28 | |
where is the file..... can u mail it to me @ sharantillu@gmail.com Ill try |
June 22, 2009, 07:43 |
wind turbine 3D rotor cfx-11 simulations___error
#29 |
FATAL ERROR : |
| | | Initial values are required for all variables in TRANSIENT runs. | | In this simulation, no initial value was set for | | | | Variable : Pressure | | Domain : rotordisc | | | | The value can be set using the Initial Values panel in CFX Pre. | | | | To bypass this message and use default solver initial values, | | set the expert parameter "transient initialisation override = t"
sivaramakrihnaiah |
July 15, 2009, 11:57 |
#30 |
Andy Good
Rep Power: 17 |
James and Ken (and others),
I have been reading your comments and you seem to know what you are talking about! I am at the early stages of a research project to model a HA tidal turbine (similar to you James). A major difference is that I am focusing on the wake from the device as opposed to its output power. I am planning my geometry/mesh creation at the moment and am trying to decide between rotation techniques (sliding mesh or rotating reference) and whether to generate a single blade with periodic BCs or the whole turbine. I am fairly new to CFD so any thoughts you all have would be greatly appreciated. Thanks, Andy |
July 20, 2009, 15:28 |
#31 | |
Skeptic
Rep Power: 17 |
I would like to see a more independent assessments of small-scale wind turbine performance in urban areas. Some of the results I have seen are very poor. In general, small-scale => low Reynolds numbers => low lift, which is not good for lift-type VAWT. Drag VAWT (e.g. Savonius rotors) are not good for generating large amounts of electricity. |
July 25, 2009, 09:13 |
#32 | |
Skeptic
Rep Power: 17 |
One trend I have noticed lately is an increase in the number of environmental snake-oil salesmen. |
July 27, 2009, 11:58 |
Optimum and equilibrium rpm
#33 |
Anonymous
Rep Power: 17 |
Hi all,
I didn't read all posts, but to answer to the first post, to find the optimum rmp you should use a BEM method, CFD is very slow for this. Next to that, there is no equilibrium rpm! The equilibrium rpm that will be reached depends on the amount of "electrical brake" that is given by the generator. So, the user decides how fast the rotor should go, if you don't it will simply accelerate upto a maximum and not generate any power at all. Cp depends on the blade pitch angle beta and the tip speed ratio lambda Cp=Cp(beta,lambda) - Beta is the angle that the tip chord (even though it's zero, so a virtual tip chord) makes with the rotor plane (defining zero geometrical twist at the tip) - Lambda is defined as Vtip/Vwind=omega*r/Vwind If you plot cp in 3D as a function of beta and lambda, you'll find a smooth hill with a certain maximum at let's say (lambda_opt,beta_opt), the easiest way to find this maximum is using a BEM, you then run the CFD at the conditions where the BEM tells you you ought to run it. I don't see any reason to run unsteady rotor acelerations in CFD. |
April 20, 2010, 06:46 |
fluent analysis
#34 | |
yashwant
Rep Power: 16 |
i am doing wind turbine analysis using fluent. i hav some query with boundary conditions . how to rotate the blade rotor and how to calculate the power in fluent software. thanks |
April 26, 2010, 06:26 |
#35 |
james britton
Rep Power: 16 |
Anyone had a play with the rigid body motion in CFX on a wind turbine?
I did for a bit for a seminar we were running but couldn't get it to converge in time so just left it |
October 24, 2010, 10:19 |
CFD wind turbine blade
#36 | |
1. should the airfoil be modeled in facing the velocity at the tip or at its lower side. (if there is no angle of attack) 2. How to compute power from Fluent? Please reply |
March 30, 2011, 04:17 |
#37 | |
Naimish Harpal (MS Aerospace Engr)
Rep Power: 17 |
Hi Guys,
I am interested to similar work, and a good news is that I have recently discovered a CFD methodology which can calculate the output RPM, Torque, Angular Velocity, and thus the actual Power for a given wind turbine, i.e. no need to define any RPM. As a sample test case, the CFD results and calculations are presented in attachment (URL: https://sites.google.com/a/cfdmax.com/fsi_vawt/). Please have a look and if you are interested, let's have a further chat. Thanking you, Naimish Harpal -------------------------------- Quote:
March 30, 2011, 04:42 |
#38 | |
Raashid Baig
Rep Power: 16 |
Consider my post as a general information. For the newbies in CFD analysis of wind turbine here are 2 very good papers you should read before starting your analysis. "Predicting 2D Airfoil and 3D Wind Turbine Rotor Performance using a Transition Model for General CFD Codes", R. Langtry, J. Gola and F. Menter, ANSYS CFX, Otterfing, Germany, AIAA-2006-0395 44th AIAA Aerospace Sciences Meeting and Exhibit and http://wwweng.uwyo.edu/mechanical/fa...-2009-1221-908 Caution - CFD analysis of wind turbine is a tough nut to crack according to my experience. Raashid |
March 30, 2011, 11:43 |
#39 | |
Skeptic
Rep Power: 17 |
Have you tried modeling other, more efficient, types of VAWT? |
March 30, 2011, 20:20 |
#40 |
Rep Power: 17 |
Thanks for your comment. Since I was just testing the methodology of rotating frame, I selected a simplest blade profile. My near future target is to apply analogous technique for HAWT, and validating my results. If you can help to suggest me any known experimental data, then it would be grate to me.
- Naimish |
Wind Turbine Analysis Suggestion | andrea.pasquali | OpenFOAM | 13 | March 25, 2015 06:27 |
CFX Analysis of a wind turbine | Bournegenius | CFX | 16 | August 20, 2012 20:16 |
ICEM CFD creating the grid of a Wind Turbine blade | Dan | CFX | 11 | June 1, 2012 15:11 |
Help Required on CFD for Turbine Blade Analysis | kkjj2008 | Main CFD Forum | 5 | July 9, 2009 16:41 |
Frozen Rotor and Wake of a Wind Turbine | Peter | CFX | 0 | June 26, 2006 16:12 |
