first grid size for a given y-lus
Old   February 2, 2011, 18:16
Default first grid size for a given y-lus
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
hi
i am going to model a turbulent flow over a flat plate.
if i want to extract a given y-plus, how can i set the first grid size?
is there any formula to calculate the distance between wall and first grid in a given flow?
thank you in advance
morteza08 is offline   Reply With Quote
Old   February 2, 2011, 19:03
f-w
f-w's Avatar
f-w is on a distinguished road
http://geolab.larc.nasa.gov/APPS/YPlus/
f-w is offline   Reply With Quote
Old   February 2, 2011, 19:27
morteza08's Avatar
Morteza
Originally Posted by f-w View Post
thank you dear friend
another question.. i mentioned that i want to model a flat plate.. is this calculator can be used for flow over any arbitrary geometry or this is only for flat plate?
Old   February 3, 2011, 13:05
f-w
f-w's Avatar
At the top of the page:
"This page provides a worksheet for estimating the normal spacing to be used in a viscous CFD grid. Estimates are for a turbulent flat plate in free air and are based on the Sutherland formula for viscosity."
It's a good starting point for arbitrary geometry. Run your simulation (not necessarily until convergence) and plot y+; then adjust mesh accordingly.
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
grid size jay Siemens 6 September 5, 2008 06:00
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
increasing grid size kcg Siemens 5 April 8, 2007 19:26
Grid size and combustion simulation versi Main CFD Forum 4 February 16, 2004 07:42
