oil/water flow in pipeline
Old   December 15, 2004, 11:20
Default oil/water flow in pipeline
pkt
I am working with a problem of oil and water flow in pipelines. I want to simulate the interface between those two fluids and so I thought that the VOF model implemented in FLuent would be Ok . But in fact not, it gives some strange results, and it is not possible to track these instabilities which are going to developped along the pipe (horizontale or inclined). I have read several post about free surface problem . and some of you suggest to use Flow3D. Is it going to work in this case (3d flows in a pipe)?. Do somebody have others advices ?.
Thanks for the help Pkt
Old   December 15, 2004, 11:44
Default Re: oil/water flow in pipeline
Jim_Park
Sorry I don't know the answer to your question.
But try www.flow3d.com. You can e-mail them a question - or call them. When I was using the program (10 years ago) I found them to be helpful.
Good luck.
Old   December 15, 2004, 12:00
pkt
Ok Thanks,
In fact , it is a question about the VOF implementation in different codes . I have read that FOAM is using a VOF too. Any users whom experienced that too ?.
Thanks
Old   December 15, 2004, 12:24
Hrvoje Jasak
Yup, I've done a lot of free surface in FOAM. If you want to see a good example, there is an SAE paper with LES + free surface and a a thesis on air bubbles in water with instability.
Hrv
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 23:08
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
