time step in steady state
Old   February 2, 2011, 12:40
Default time step in steady state
vishnu
naveen_010 is on a distinguished road
Dear users
I understand both steady and unsteady solvers will involve calculation of time steps. I usually calculate time step for unsteady case by CFL criteria. For steady case there will be psedo time step, how does the solver calculates this psueotime step .
Thanks & Regards
vnnnn.
naveen_010 is offline   Reply With Quote
Old   February 3, 2011, 02:31
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
It depends on the software you are talking about. Implementation of steady-state solver usually uses either of the following:
- An under-relaxation term (in place of a transient term).
Note 1: some solver do solve for the steady-state equation (without transient or under-relaxation terms), but usually needs to get close to the solution first (using an under-relaxation or transient term).
Note 2: the formulation of the under-relaxation term is so close to the transient one, that it is my belief that you may even be able to work it backward to an actual time. However, it is standard practice to employ different under-relaxation factors for different variables.
- a local time-step based on a local CFL. In this approach an individual time-step is computed for each individual control volume/cell and used during the integration. Consequently you loose time consistency, but convergence is faster.
Regardless of the approach the software employs, the "converged" solution should have its transient term/under-relaxation term going to zero.
Sincerely, Julien
julien.decharentenay is offline   Reply With Quote
Old   February 3, 2011, 14:18
Default timesteps
vishnu
Dear julien
Thanks for the information.
I use star-cd for my runs, do you have any idea how does star-cd calculates the time step in steady state. I run my cases by specifying the number of iterations.
My belief is steady or unsteady solver, the outer iterations are time step and inner one are iterations.
Thanks & Regards
Vnnnn
Old   February 3, 2011, 20:49
For steady-state, STAR-CD uses under-relaxation factors. There is no time-step in the integration of the solver equations. Note that there may be time-steps associated with specific models, lagrangian particle tracking for example.
The correct terminology is as follows:
- steady-state: iterations;
- transient: time-step with sub-iterations (which are used to converge the time-step).
Sincerely,
Time step size and max iterations per time step pUl| FLUENT 31 October 23, 2020 23:50
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 09:33
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Intermediate step during a time step Burn OpenFOAM 0 July 16, 2009 11:01
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
