using petsc for large coupled linear systems
Old   January 31, 2011, 13:22
Default using petsc for large coupled linear systems
sd_vakip is on a distinguished road
Hello to all,
I am in trouble using petsc.
I have solved Free-Convection flow in annulus on a 90x100 grid using PGMRES-ILUT of Saad's SPARSKIT. I am using a coupled algorithm with PWIM for face velocities to solve continuty equation with momentum and energy equations simultaneously. to It worked well up to 90x100 cells (90x100x4 equations) with non-dimensionalized time step t=5. To study the grid independency, I used 180x200 grid with the same solver settings and B.C.'snd t=5. However, it does not converge on the fine grid. I reduced the time step size up to t=0.001, but it did not work. Up to now, I have no idea about this issue: it is caused by the solver or the problem is too taugh to solve.
Therefore, I used PETSc in order to utilize more options on both preconditioners as well as solver and also, to use its parallel processing benefit.
I tests almost all preconditioners and ksp solver of petsc and they can not find a solution (do not converege) even though, for 90x100 cells!
1- How could I use the same preconditioner and solver (i.e. ILUT and GMRES with fill-in=100 and droptol=0.01) by petsc to get the same result for 90x100 cells?
2- Do you have any idea about what makes the solver to diverge when I use 180x200?
Many Thanks,
sd_vaki
sd_vakip is offline   Reply With Quote
Inversion of large sparse linear systems pankos Main CFD Forum 4 June 24, 2010 07:24
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
IdeasUnvToFoam Bug amp Fix benru OpenFOAM Bugs 42 November 13, 2009 08:59
Water pump OpenFOAM 15 ANSYS CFX 110 comparation waynezw0618 OpenFOAM Running, Solving & CFD 39 March 5, 2009 13:57
Non linear coupled boundaies tamer Main CFD Forum 0 June 12, 2003 03:46
