reference calcultion, flow around a cylinder
Old   January 26, 2011, 10:49
Default reference calcultion, flow around a cylinder
butch85 is on a distinguished road
i'm about to simulate the flow of water around a cylinder.
i do this for the first time and it is part of my final work to become
bachelor degree.
what i'm looking for is some reference calculation or measuring report about any kind of flow around a cylinder. my idea was to simulate a flow around a cylinder based on a proved solution and see if i'm able to simulate it. if my simulation is near reality it's god, if not i have to change something
i searched the internet but i was not able to find anything useful. maybe one of you got an idea or had the same problem
thank you very much
butch85 is offline   Reply With Quote
Old   January 30, 2011, 05:54
Rami Ben-Zvi
Rami is on a distinguished road
Have a look at works by Zukauskas, specifically the two books
  • Tube Banks in Crossflow
  • Advances in Heat Transfer 18, 1987 (in the chapter by Zukauskas)
The later is more concise version of the first. In both, the case of flow around a single cylinder is discussed prior to treatment of rows of cylinders and tube banks.
Rami is offline   Reply With Quote
Old   January 30, 2011, 08:06
KHB
lava12005 is on a distinguished road
I'm also doing flow around a cylinder currently, mine is about VIV with immersed boundary method.. You can find a number of paper out there which present the result of a flow around a fixed cylinder.
For example if u want experimental result, there is this "Experiments on the Flow past a circular Cylinder at Low Reynolds Number" by D.J.Tritton. This paper only give u result for low reynold number, <= 100 If I'm not wrong..
Good luck!
lava12005 is offline   Reply With Quote
Old   January 31, 2011, 17:10
thank you very much for the answers
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 11:05
flow resistance of cylinder in parallel flow Ralf Schmidt Main CFD Forum 3 May 11, 2009 03:26
flow around circular cylinder...plz help yousef FLUENT 4 March 28, 2006 12:01
Flow around a cylinder at subcritical regime. yousef FLUENT 0 March 18, 2006 10:18
