shock tube validation
Old   November 21, 2004, 19:49
Default shock tube validation
AB
I have done a shock tube analysis in Star-CD and I need to validate it. Can some one tell me how to validate my results with analytical results or from the shock tables.
What all variables do I need to check for validation and what pressures should I look for.
I have some idea and I need some other tips from u to extend it.
Regarding validating shock tube, I would just go to the normal shock tables in which property ratios are tabulated as a function of Mach number.
Find total pressure ratio on the table and see what M1, M2, T2/T1, etc. that corresponds to.
For example, for Pt2/Pt1=0.4990, M1=2.50, M2=0.5130, T2/T1=2.137, Ps2/Ps1=7.125, and D2/D1=V1/V2=3.333 (D=density). V1 = M1*sqrt(gam*Rgas*T1) V2 = V1 / (V1/V2) shock speed = V1 - V2
But I have given a pressure and temp to one side of a tube and different pressure and temp to other side . what scalar data should I look for in my results ??
Can someone help me!!!
Thanks,
AB
Old   November 23, 2004, 08:24
Default Re: shock tube validation
Banaeizadeh
Look, I think it is better that you refer to Gas Dynamics Book by James John, in the shock tube section there is a simple shock tube problem, you can use its initial data and then try to get the results which are availible in it. Banaeizadeh
Old   November 24, 2004, 07:04
Praveen
The solution obviously depends on the initial condition. You can get some IC from Toro, Riemann Problems and Numerical Methods for fluid dynamics. This book also gives fortran code for exact solution of shock tube problem which can be used for comparison.
Old   December 10, 2004, 08:31
Krishna Reddy
u can get exact analytical results for shock tube problem in 1.Modern Compressible flow- Anderson 2.Numerical Computation of External and Internal Flow -
volume 2- C.Hirsch
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 03:10
Shock tube simulation harish FLUENT 5 January 25, 2014 03:20
ghost fluid method (shock tube problem) Amir Main CFD Forum 0 March 1, 2009 07:16
shock tube validation AB Siemens 0 November 21, 2004 19:43
Shock tube problem AB Siemens 1 November 9, 2004 01:25
