November 19, 2004, 05:26 |
Question about tensor notation !
Hi, everyone.
I have one question about tensor notation. du_i / (dx_j dx_k) 'd' means partial derivative and i,j,k are index notation. above tensor notation showed in epsilon equation of k-e turbulence mode. (Yang and Shih,1993) I am very qurious about developing tensor notaton to cartesian form. thanks in advance. |
November 19, 2004, 07:29 |
Re: Question about tensor notation !
I think your epsilon eq. is not in the tensor notation. Rather it is in the indicial notation. In complete tensor notation you should have the symbolic form of the metrics multiplied to the different terms. The form of the metric is different in different spaces. Regarding the derivative you posted, I think it is already in the cartesian form. If you are assuming a 3D system then i,j,k independently take the values 1,2,3. 'x_1' means 'x', 'x_2' means 'y' and 'x_3' means 'z'. Further, 'u_1' means 'u', 'u_2' means 'v' and 'u_3' means 'w'. Since epsilon is a scalar therefore each term in the epsilon eq. must contain the indices i, j and k twice. When a index occurs twice in a term then you have to invoke the summation convention.
question about uds | tanven | FLUENT | 2 | July 5, 2015 12:22 |
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 17:03 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 16:26 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 06:55 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 05:57 |
