Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case
Old   January 6, 2011, 09:36
Default Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case
LittleBart
LittleBart is on a distinguished road
Dear friends,
I'm working on the case when I have to simulating airflow over a wind turbine blade. The problem is to determine total lift and drag force occurred over the blade in rotation but instead of making rotating blade and solve transcendent case, I've decided to apply velocity gradient to the Inlet BC. wR - gradient will simulate the blade's rotation.
The question is how to apply such a parameter of the BC ?
Was trying to do this with CFX 12 and Fluent but didn't succeed
LittleBart is offline   Reply With Quote
Old   January 6, 2011, 10:53
Lukas
Nixmich is on a distinguished road
Hi, dunno abount Fluent but in CFX pre you can "add an Expression" like vel=2*x/1[s] and then just type "vel" as the inflow speed. Is that what you mean?
Nixmich is offline   Reply With Quote
Old   January 7, 2011, 08:42
LittleBart
Thanx
is there any place in help or other documentation where I can read about such an expressions ?
and one more - in your example as I understood "x" - is a coordinate? Do I have to create special coordinate frame or coordinate system to specify this coordinate frame?
thnx once again
Old   January 7, 2011, 09:06
Robert
RobertB is on a distinguished road
Can't you pose the problem in a rotating reference frame? It would make the setup easier.
RobertB is offline   Reply With Quote
Old   January 10, 2011, 03:23
Lukas
you don't have to set up an extra coordinate frame, x refers to the one in which you set up your geometry.
anyway, it's all in the cfx tutorials.
Old   January 10, 2011, 16:07
LittleBart
Thanx, I will lurk more ...
I'm just beginner in such analysis so I just don't now what book to begin with.. But I will try anyway ... thnx
blade, cfx, fluent, turbine, wind
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 07:35
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 11:32
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
