Pressure Far Field&Velocity Inlet-Pressure Outlet
Old   January 1, 2011, 10:44
Default Pressure Far Field&Velocity Inlet-Pressure Outlet
İlyas Karasu
saylilyas is on a distinguished road
I am analyzing NACA0012 wing profile at low Reynolds Numbers.(135000). I must do this with pressure far field and velocity inlet-pressure outlet. However I got good result with pressure far field boundary type (very close to experimental values) by using k w SST turbulence model but unfortunately I could not get accurete results via using velocity inlet-pressure outlet boundary types. I only changed boundary types in GAMBIT. The mesh structure,velocity values, turbulence values turbulence model gauge and operating pressures same.
I always get lower value of coefficient of lift drag and pressure (more than 40% lower of the experimental value)
If you have any idea please help me.
saylilyas is offline   Reply With Quote
pressure farfield, pressure outlet, velocity inlet
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
velocity inlet and pressure outlet Ebrahim FLUENT 5 January 15, 2015 18:14
Pressure Inlet Velocity prapanj OpenFOAM 11 June 23, 2009 12:15
Pressure Rise Error emueller CFX 0 May 5, 2009 12:08
Pressure Inlet BC Prasad FLUENT 3 January 4, 2009 23:55
