X Flow CFD? Will you use it?
Old   December 29, 2010, 16:57
Default X Flow CFD? Will you use it?
Harsh Thapar
HarshThapar is on a distinguished road
Hi, I came across X-flow cfd , a new mesh less, particle based , new fully lagrangian approach to fluid simulation ( link below)
I want to know how it compares to a mesh based software like say CFX or Fluent? Capability, suitability and accuracy?
http://www.nextlimit.com/techno_cfd.php
HarshThapar is offline   Reply With Quote
Old   January 17, 2011, 13:38
John D. Smith
j_smith is on a distinguished road
Hi Harsh,
We have evaluated XFlow 2011 in our company for several weeks and are quite satisfied with the results.
We are simulating airflow around civil structures. The software is easy and intuitive to use, results are reasonable and it has nice postprocessing capabilities. The main pro is that the meshing process is avoided, saving a lot of time. Main cons so far are that it only runs under Windows 64 OS, and analysis must be transient.
http://www.xflowcfd.com/
j_smith is offline   Reply With Quote
Old   August 5, 2011, 19:47
Wink XFlow
Med
Hammou
Med is on a distinguished road
Xflow is very easy to use. a little bit less accurate then CFD based Navier-Stockes-Equation (like CFX, Fluent, StarCD, ...) but more flexible. very good for complex geometry and moving parts. Xflow use the Lattice Boltzmann method and Lattice Gas Automata Mesh-less approach. Work only on 64-Bit OS and Only transient calculation can be made.
Med is offline   Reply With Quote
Old   July 20, 2012, 13:45
CFDfan is on a distinguished road
Originally Posted by Med View Post
How do you know for how long to run the transient simulation? Are there any flags in the software when the process reaches the stable-state condition
CFDfan is offline   Reply With Quote
Old   August 6, 2012, 09:13
Thumbs up
TrinoM is on a distinguished road
It looks like their version 2012 of XFlow includes now a Linux version, according to the hardware requirements page: http://www.xflowcfd.com/index.php/pr...w/requirements
Concerning accuracy, it doesn't look bad at all if checking their white papers posted, e.g.: http://www.xflowcfd.com/pdf/Paper03-...Prediction.pdf.
I read lattice-Boltzmann was fast for transient simulations. The pseudo-steady state of transient simulations can usually be checked by different parameters depending on your application, e.g. convergence of the forces in aerodynamics. This isn't very different from looking at a residual curve to go down.
I would give it a try.
TrinoM is offline   Reply With Quote
Old   December 21, 2012, 13:18
Default importing adams motions to xflow
sana
sana is on a distinguished road
Hi
i start to learn xflow. i have worked a lot with adams but now i need to study motion of a body in a 3d domain of a fluide. i want to simulate a motion in adams and then transfer it to xflow. in adams i first simulate motion then exported my body in step format and then export results file . in xflow i import step and results files. i saw my model shape and its motion but when i run xflow i can't see any interaction between body and fluide. also py diagram in function viewer remain zero but my shape move! note that after importing body , xflow knows it as a enforced geometry.
i do not know what should do to perform a correct importing from adams to xflow can any body help me to do that
GOOD LUCK
sana is offline   Reply With Quote
Old   December 23, 2012, 13:13
sana
Originally Posted by sana View Post
Hi
GOOD LUCK
help me some body PLEASE
Old   March 5, 2013, 04:59
Default very good for complex geometry and moving parts
王国斌
wangguobin14 is on a distinguished road
Send a message via ICQ to wangguobin14 Send a message via MSN to wangguobin14
sana
hello, now i am very good at xflow for genaral model,then with adams will be my work award step,so,do you mind let me do something for you.please keep touch with wangguobin14@163.com,ths
wangguobin14 is offline   Reply With Quote
Old   March 12, 2013, 12:56
sana
hi
i will be glad to connect with you
i worked a lot with xflow but at last i cant give suitable answers from it i am professional in adams and i wanted to combined xflow and adams but i couldn't i have bellow problems with xflow can you help me to solve them
1- when i import a adams model into xflow it converts it to an in-force body and when i run a simulation, motion of the body doesn't have any affect on fluid. then how can i do this import well? do you know?
2- in free surface simulation :
when i give a motion to the water container xflow can't simulate water motions (for example can you simulate a falling bottle or a moving container?
when i want to import a fuel tank model from solid work (it contains internal baffles and walls) xflow stops and show an error associate with its 3dengine)
3- i cant obtain a correct answers in supper sonic problems especially in zero degree pitch angles
Old   August 12, 2013, 12:22
An
mecobio is on a distinguished road
Originally Posted by j_smith View Post
Hi Harsh,
Hi j_smith, sana and others
Is there any possibility to someone to put out there a X-flow project, available as an example, to see how it works?, since I do have access to a X-Flow for few days and I want to see how it works. Unfortunately, no time to create an entire new project from scratch. It doesn't matter how simple the X-flow project is, it is just to see how X-flow works.
Thanks mecobio [ AT] hotmail.com
PS: It is strange that there is NO single example with that X-flow code.
mecobio is offline   Reply With Quote
Old   June 12, 2016, 15:55
Default High wardware coast
  #11
Markoz
shlxtn is on a distinguished road
Hi
I have one question.
X-flow require more giga B RAM, I think more than 6 Giga.
Thank you
shlxtn is offline   Reply With Quote
software, x flow
CFD of laminar reactive liquid flow Ingo Meisel Main CFD Forum 5 March 12, 2004 05:38
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 04:03
CFD book on Multiphase flow sanjib das sharma CFX 0 September 6, 2001 03:45
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 09:19
