September 24, 2013, 09:53 |
#21 | |
Filippo Maria Denaro
Rep Power: 73 |
September 24, 2013, 10:58 |
#22 | |
Thank you |
January 30, 2014, 07:32 |
Deflagration not Detonation
#23 |
Richard Chinery
with respect to the earlier posts on combustion effects on what would normally be incompressible flow, simple temperature correction accounts for change in density. you could use combustion intensity figures to plot the heat release and continually account for this?
i don't see the need for use of compressible flow considerations unless you are considering detonation. |
September 1, 2016, 11:52 |
#24 | |
larmes
Rep Power: 10 |
March 18, 2017, 05:01 |
#25 |
CHUNG Ching Chun
Rep Power: 10 |
Dear all,
I have been doing 3D validation case of flow over a bump-in channel from NASA Turbulence Modelling Center. https://turbmodels.larc.nasa.gov/bump3d.html I get floating point errors when I am using an incompressible solver but it runs fine with an incompressible solver. Its velocity is 0.3 Mach number. Is it usual to assume that it is compressible flow so that my results will not be wrong? Also is it ok to use a compressible flow for a case that I am not sure, whether there are compressibility or not? |
March 18, 2017, 05:31 |
#26 | |
Rep Power: 73 |
March 18, 2017, 05:46 |
#27 |
CHUNG Ching Chun
Rep Power: 10 |
When I use a OpenFOAM incompressible CFD solver, like pimpleFoam, its continuity error goes up to around e+90 and its velocity field values are also absurdly high. According to the error messages, it says floating point errors and I think it means it is taking up too many bytes.
However, when I use a compressible solver, rhoPimpleFoam, everything goes fine. To be frank, why does that happen? Do anyone has experience about that? |
March 18, 2017, 13:25 |
#28 |
Rep Power: 73 |
floating points error is not due to the lack of memory space but it means that the number is so big to be not representable on the registry machine...
The first thing I could immagine is a wrong setup of the case or a numerical instability. |
Incompressible to compressible flow simulation | Nishikant Tamrakar | FLUENT | 10 | June 16, 2009 22:09 |
compressible and incompressible flow | chinababu | FLUENT | 4 | November 13, 2008 06:56 |
Incompressible and compressible flow. | John. | Main CFD Forum | 1 | December 15, 2004 12:29 |
convert compressible flow into incompressible flow | Hun Jung | Main CFD Forum | 4 | August 11, 2003 11:10 |
Incompressible and compressible flow | boris | FLUENT | 0 | February 20, 2002 04:08 |
