3D simulation of wind turbine in Yaw wind(in a lateral wind)
Old   December 28, 2010, 04:26
Default 3D simulation of wind turbine in Yaw wind(in a lateral wind)
mohammad
mohammad is on a distinguished road
Hi everybody.
I'm trying to simulate a two balded wind turbine in a lateral wind....( yaw position). in this case, wind is not purely axial and then the behavior of the two blades are different.
When one blade is going to the wing( advancing blade) , the other is rotating in the opposite direction( retreating blade). Then, every thing about the aerodynamic forces depends upon the instantaneous position of the blades and every thing will be unsymmetrical.
now my question is that can you please help me how to simulate this kind of situations?
thank you in advance.
mohammad is offline   Reply With Quote
forward flight, wind turbine blade, yaw
Torque of wind turbine simulation caohan FLUENT 8 August 12, 2014 00:01
I want to simulate a wind turbine in a yaw position ( lateral wind) mohammad FLOW-3D 1 January 17, 2011 02:41
wind turbine modeling jkkibrahim OpenFOAM 0 April 29, 2010 13:34
wind turbine simulation moca CFX 1 July 25, 2009 07:48
wind turbine aerodynamics bharat Main CFD Forum 1 November 29, 2004 12:26
