STL file convertion to IGES Surface format
Old   November 12, 2004, 09:39
Default STL file convertion to IGES Surface format
jens
Does anyone know a free tool that can be used for translating a polygon STL file to a IGES Surface file.
Inorder to import it into oure CAD software for building models for oure CFD software.
Thanks in advance.
Kind Regards
Jens
Old   November 15, 2004, 06:44
Default Re: STL file convertion to IGES Surface format
Anshul Gupta
I have been trying to look into one myself for years and haven't got any. In fact, I don't know even a paid software which does a good job on such situations! It is mathematically very challenging job and lot of people gave up trying it out.. Those who can do it, in fact, create a NURB surface for every STL triangle Well, that's not quite bad though..
Old   November 24, 2004, 04:13
queram
to develop such a code could be a job for someone; as a master or a phd thesis. I tried some things using stl format (conversion of 3D pipe geometry into 1D scheme, export/import between catia, ansys, icemcfd..) but found that ascii format (generated by catia) contains many errors prohibiting correct data transfer. binary format seems to be free of such errors, but many of the tries were not successful. it seems to me it depends on the computer (or code) instantaneous mood or weather or what
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 11:45
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
