Need help for loss coefficient of elbow diffuser
Old   November 9, 2004, 03:54
Default Need help for loss coefficient of elbow diffuser
Pete
Hi pals,
I'm working on the 90 deg elbow diffuser(inlet circular cross section & outlet rectangular cross section). The fluid is air at 25 deg c, 1 atm. Design inlet velocity is about 20m/s. Inlet to Outlet area ratio is 1:5.
Can anyone kind enough to advise me on how to estimate the pressure loss coefficent for this diffuser so that I can use it to get a realistic static pressure for the outlet boundary condition? Please let me know if you have any rough idea about the value of this loss coefficient.
Please help if you can.... Any ideas will be appreciated.
Thanks,Pete
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
