Tube inside a tube simulation
Old   December 14, 2010, 02:52
Question Tube inside a tube simulation
Rashmichem is on a distinguished road
Hi
Iam simulating tube inside a tube 2D simulation with co-current laminar flow. water is flowing in outer tube and oil inside the inner tube. the geometry is inclined to 45 degrees. inlet conditions:
oil temp: 71 degrees C
oil velocity: 0.003m/s
water temp: 25 C
velocity: 0.00029
outlet conditions:
not known
outer tube wall is adiabatic
In gambit
created 2 D geometry. rectangle inside another rectangle. selected edges to define BC oil inlet, water inlet, oil outlet and water outlet. edges along the length as inner walls and outer walls. defined zones for fluid (oil and water).
In fluent
using steady state, laminar model, defined materials,
boundary conditions:
oil: fluid: motion type-->moving reference frame
translational velocity: x=0, y=0.003m/s
same for water with velocity of 0.00029m/s
inlet conditions: velocity magnitude n direction: x=0, y=(given vel for oil and water)
defined gravity in y=-9.81
i tried simulating using laminar and k-e model. difficult to converge.
need help and suggestions.
Rashmi
Rashmichem is offline   Reply With Quote
laminar flow, tube in tube
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 03:10
liquid temperature at tube outlet? phsieh2005 Main CFD Forum 0 October 11, 2010 21:33
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 14:24
Draft tube and MFR/SG nyatoto CFX 0 June 3, 2003 06:55
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
