NACA 0012 mach 0.5 6 degrees
Old   December 8, 2010, 13:30
Default NACA 0012 mach 0.5 6 degrees
Papis
papis is on a distinguished road
HI,
I have a code that solves the viscous/inviscid cases.I am working on the validation of the code and i have seen a shock wave appearing at mach 0.5 at 6 degrees(inviscid case) but only in fine grids.The strange thing is that in coarse grids as well as in viscous cases the shock isn't there(cl ~0.75 in coarse grid ~0.669 in viscous cases).However when i use a fine grid to run the inviscid code a shock appears and the lift coefficient is around 0.85...
I know it's weird and i am looking for a bug for a while now but nothing came up.Has anyone here experienced anything like this?
papis is offline   Reply With Quote
Old   December 9, 2010, 12:27
Papis
It would help me much if somebody was able to run an inviscid naca0012 on a fine grid at mach 0.5 at a = 6 degrees and post the pressure coefficient.
Thanks again.
Old   December 10, 2010, 03:38
Alexey
ignat is on a distinguished road
Originally Posted by papis View Post
The strange thing is ...
This thing is not strange because all difference schemes have non-physical (artificial) viscosity depending on grid spacing. Your shock is weak and it smeared at coarse grid. It is natural phenomenon.
ignat is offline   Reply With Quote
LiftDrag tool nuovodna OpenFOAM Running, Solving & CFD 45 September 2, 2009 18:56
Problems with flat plate and NACA 0012 Lift/Force Harly FLUENT 0 June 18, 2007 11:02
Naca 0012 Raj FLUENT 2 September 23, 2006 16:55
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 12:42
non-dimensional analysis in Fluent Endee FLUENT 8 September 7, 2005 17:16
