Iterative solution to Poissons Equation
Old   December 8, 2010, 13:28
Default Iterative solution to Poissons Equation
Philip Piper
Phiper is on a distinguished road
Can someone please explain either the SOR iterative solution to Poissons Equation or any other that may be faster? I'm having trouble wrapping my head around the concept of how this equation can be used to create a mass-conserving field. Thanks for any help!!!
**Edit: Or link me to any explanations or previous threads
Phiper is offline   Reply With Quote
Old   December 8, 2010, 14:42
Dan
dandalf is on a distinguished road
I have attached a quick derrivation of the pressure poisson equation, I hope this explains how it maintains conservation of mass.
The pressure requirements at physical boundaries can also be derrived useing similar methods,
As for solvers, I have been using a direct itterative Gauss -Seidel method, although I would welcome any sugestions for an alternative.
dandalf is offline   Reply With Quote
Old   December 9, 2010, 16:01
TWB
quarkz is on a distinguished road
Are you trying to solve the Poisson eqn? You can try multigrid which is very suitable for Poisson eqn. PETSc and hypre can be used together to solve your Poisson eqn.
quarkz is offline   Reply With Quote
Old   December 9, 2010, 19:58
Philip Piper
Yes I've heard of multigrid before. I just don't understand how it works. And I've looked at a few explanations online but i havn't really found them satisfactory.
Old   December 10, 2010, 02:58
Alexey
ignat is on a distinguished road
I think conjugate gradient method with preconditioner is faster then SOR.
I recommended to use Saad's SPARSKIT library, see here
http://www-users.cs.umn.edu/~saad/so...KIT/index.html
ignat is offline   Reply With Quote
Analytical solution of poisson equation kostaspan Main CFD Forum 1 April 22, 2010 13:24
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 08:52
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 15:01
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
solution to Burger's Equation using fortran Tony Limjuco Main CFD Forum 4 April 2, 2005 01:41
