December 3, 2010, 13:41 |
creating two benchmark examples
vladimir nikolic
dear sirs,
i would like to create two benchmark examples for CFD. the examples should be 1) straight cylinder fluid flow 2) rectangle tube fluid flow i would like to compare the results with analytical solutions for those problems. i know that there are analytical solutions for them and i do have equations that are depending on deltaP (pressure drop) ( eg. Hagen–Poiseuille equation) i would like to find equations that are depending on Q (flow rate) if possible. maybe even some other benchmark example would do the job for me but only if they are function of Q or V (fluid velocity) i am sorry if you found this question not so adequate - i am beginer thank you for your interest |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 16:33 |
[blockMesh] Problems in creating a wedge type mesh | Joscha | OpenFOAM Meshing & Mesh Conversion | 28 | August 3, 2019 08:59 |
Benchmark validation examples? | Fred | Main CFD Forum | 2 | October 9, 2008 19:30 |
Problems with Meshing: Collapsed Cells | Emmanuel Resch | Siemens | 1 | July 30, 2007 04:02 |
Gerris software installation | mer | Main CFD Forum | 2 | November 12, 2005 09:50 |
