Maintaining symmetry on a staggered cartesian grid,
Old   December 2, 2010, 06:54
Default Maintaining symmetry on a staggered cartesian grid,
Dan
dandalf is on a distinguished road
Hi all, I'm using a 2D staggered cartesian grid to model a simple flow over a cylinder.
This is equivelent to a finite volume method, each volume element, consits of a pressure at the center p, a horizontal velocity at the western wall u, and a vertical velocity at the southern wall v,
I have enforced the following velocity boundary confitions,
If southern wall solid is solid
v=vobj
if western wall is solid
u=uobj
else calculate as velocity as normal.
And I am enforcing the pressure boundary conditions,
\frac{\partial p}{\partial n}=F_n +\frac{u_n^{it-1}-u0bj_n}{\Delta t}
where n is the direction normal to the boundary, and F is the function such that,
\frac{\partial u}{\partial t}= F_x - \frac{\partial p}{\partial x}
However the results I am getting seem to favour a positive lift coeficient, no doubt due to the lack of symmetry, and tends to settle on a steady state flow when it shouldent
The model otherwise agrees well with benchmark solutins
Is there an easy way to regain symetry? or do I need more sophisticated boundary handeling?
dandalf is offline   Reply With Quote
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 17:31
Semi Lagrangian method and Staggered Grid JEONG MO HONG Main CFD Forum 1 May 26, 2003 02:43
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
