Hydraulic Diameter
Old   November 29, 2010, 19:46
Default Hydraulic Diameter
RUZ
ruzfactor is on a distinguished road
I'm trying to solve a sudden expansion mesh in FLUENT using K-e model. I'm using turbulent intensity and hydraulic diameter for giving turbulence BC. I want to what should be the hydraulic diameter for a axisymmetric sudden expansion and also how do I guess the value of turbulence intensity?
ruzfactor is offline   Reply With Quote
Old   November 30, 2010, 04:10
Administrator
pete's Avatar
Peter Jones
pete will become famous soon enough
CFD-Wiki contains an estimation of the turbulence intensity in a fully developed pipe flow. see http://www.cfd-online.com/Wiki/Turbulence_intensity. That page also links to the definition of the hydraulic diameter.
pete is offline   Reply With Quote
Old   November 30, 2010, 07:49
RUZ
For a sudden expansion there are two diameters. which one should be taken into account when I'm interested only the flow behaviour at the downstream of the expansion.
can you please help me setting the BC for a sudden expansion?? I really need some help here.
Old   November 30, 2010, 07:53
Administrator
pete's Avatar
Peter Jones
What you want to compute are boundary conditions at the inlet, right? Then it is the inlet dimensions that you should use.
Old   November 30, 2010, 08:13
RUZ
yes. BC at inlet.
Old   November 30, 2010, 08:15
siri is on a distinguished road
so simple!
n eureka ! i just discovered that .. any response < 10 characters won't get submitted to the forum.
P.S: was it to stop spam ?
siri is offline   Reply With Quote
Old   November 30, 2010, 08:46
RUZ
I'm posting the pics of sudden expansion. The inlet dimensions were variable in the actual experiment but How do I do that in the given mesh? I have to compare the results with the experimental data.
Hydraulic Diameter - Series of Holes Jop FLUENT 6 January 14, 2019 10:41
equivalent diameter vs hydraulic diameter swamysrikanth FLUENT 1 October 12, 2013 02:18
[GAMBIT] hydraulic diameter? Zweeper ANSYS Meshing & Geometry 6 January 4, 2010 01:44
hydraulic diameter in 2d ahsan FLUENT 2 August 28, 2009 16:22
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 11:58
