Turbulence beginner
Old   October 25, 2004, 20:29
Default Turbulence beginner
vasanth
I am a beginner in turbulence.I have been going through some basic stuff on turbulence and did not understand a couple of things.
1)The asymptotic assumption says that as Reynolds number tends to infinity the shear flow becomes independent of most of its environment,except for boundary conditions imposed by the overall flow. What is the meaning or significance of flow getting independent of its enverionment?
2)The small scale eddies have very short time scales,which tend to make them statistically independent of the mean flow.I did not understand this statement at all.What is statistically independent?
Thanks in advance Vasanth
Old   October 26, 2004, 06:01
Default Re: Turbulence beginner
R
1. Viscosity tends to zero.
2. Mean flow do not have an effect on these eddies.
Old   October 29, 2004, 12:19
vasanth
Hi, Viscosity is a property of a fluid.How can viscosity tend to zero.I mean how can it change. Thanks
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 05:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
