Boundary conditions low Mach number flow
Old   November 28, 2010, 05:44
Default Boundary conditions low Mach number flow
lost.identity is on a distinguished road
I'm trying to study a low Mach number flow with variable density using the SIMPLER algorithm. The real problem is that of a spherically expanding flame from a point source in an unconfined space.
The physical boundary conditions are the velocity u=0 at the origin and u=0 at the far-field and pressure p=p0 at the far-field. The problem is essentially 1-D so I use a 1-D domain with a staggered grid for computations.
It is my understanding that for such a problem I only have to define either pressure or velocity at the boundaries. I seem to be getting incorrect results and I think I have issues with boundary conditions. Right now I have,
at the centre, r=0, u=0
at the far-field, r=R, du/dr = 0
I use the discretised pressure equation to obtain the pressures at the boundary using the velocities calculated at the boundary, i.e. I don't specify a particular pressure value at the boundary, it is taken from the solution.
Can anyone tell me if I'm doing anything wrong? Thanks.
lost.identity is offline   Reply With Quote
bcs, simpler algorithm
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 06:35
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 13:16
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Outlet boundary conditions for unsteady flow Bjorn B Main CFD Forum 3 January 11, 2006 06:42
Low Mach Number Flow Mohammad Kermani Main CFD Forum 0 February 25, 2002 00:47
