Convergence and flow stability
Old   October 22, 2004, 03:36
Default Convergence and flow stability
Prevani Kistan
I am doing cfd simulations on missiles at different angles of attack. At higher angles of attack...alpha 30 and above...I experienced problems with trying to get the solutions to converge. Is this in anyway a reflection of the stability of the flowfield on the missile at those angles of attack? Can one use the fact that since something is not converging or is taking an extremely long time to converge as an indication that something is wrong with the way the problem is defined or that the solution itself is not stable?
Software being used: CFD-FASTRAN turbulence model: Menter-SST Thanks
Old   October 24, 2004, 10:06
Default Re: Convergence and flow stability
versi
high AOA flow tends to be unstable, flow is either periodic, aperiodic, chaotic or turbulent. Then you can not expect to converge to steady state in general cases.
Old   October 25, 2004, 03:00
Prevani
Thanks versi. Another question: Are there any papers available that relate flow features to convergence?
Old   November 12, 2004, 21:23
rivers
everything can be copyrighted. http://www.uscomco.org/dish/ http://www.uscomco.org/alltel/
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Problem with Convergence at high flow rates Syed Siemens 1 April 10, 2007 16:18
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Convergence for inviscid flow over sylinder Rjakk Main CFD Forum 2 March 21, 2007 11:53
Convergence in Flow between corotating disks Felipe FLUENT 7 January 27, 2004 11:20
