Simulation Volume Questions - Size/Distance from model
Old   November 22, 2010, 14:19
Default Simulation Volume Questions - Size/Distance from model
stucke is on a distinguished road
Pardon My ignorance, but I am looking to start off on the right foot with my series of simulations.
What is the standard distance that most meshes are extended upstream (how many calibers), around the model, and downstream?
Are there any metrics that are generally used, such as vorticity, to determine if the volume was too small or too close to the model?
I am hungry for information, if you have and references that you recommend, I'll gladly check them out.
Thanks,
Russ
stucke is offline   Reply With Quote
mesh volume., size, volume
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Polyflow Simulation with ViscoElastic Model memory problem sid2909 ANSYS 0 May 10, 2010 06:27
help, error spray simulation in contant volume chamber with kiva toto Main CFD Forum 0 June 8, 2009 10:52
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 10:53
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
