Laplace operator in finite element formulation
Old   October 18, 2004, 19:20
Default Laplace operator in finite element formulation
Rafael
Hi together,
I try to discretizise the pressure poisson equation (for an incompressible viscous code).
Well, the discretization of the LHS (laplace operator for pressure) yields to a symmetric matrix L (multiplying element B matrix and its transpose BT) before the nodal pressure.
Now, for getting the pressure, I have tried both: (a) to invert the matrix L or (b) to solve a equation system like Lx=B.
PROBLEM: Both failed with the message "L is singular".
Do you know, where I did the mistake?? If no mistake, please give the trick how to solve this.
Extra information: - I used the same (linear) shape functions for velocity as well for pressure
Thanks a lot in advance!!
Rafael
Old   October 19, 2004, 09:43
Default Re: Laplace operator in finite element formulation
Jim_Park
Take a look at your boundary conditions.
With the pressure equation, the matrix becomes singular when the pressure is not specified at (at least) one node. In an incompressible flow, the pressure is usually known to within a constant anyway, so specifying at a node fixes the pressure levels without modifying the pressure gradients (and thus the velocities).
Likely a FEM expert will answer this with FEM-based language, and perhaps a 'standard' way to fix the problem.
Old   October 19, 2004, 22:09
Rafael
Yeah Jim,
that was it. I apologize, I did not consider (for a first run) the boundary condition term of pressure poisson equation.
Thank you for your help! Regards, Rafael
finite volume VS finite element solomon FLUENT 4 April 3, 2015 01:10
How can be calculate a surface integral in the finite element method? HectorRedal Main CFD Forum 3 March 13, 2015 09:25
Control Volume Finite Element Method gerardosrez Main CFD Forum 0 March 16, 2011 15:49
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 20:24
Rheolef: a C++ finite element library for solving PDE (annonce) saramito Main CFD Forum 0 October 14, 2009 05:58
