May 12, 1999, 16:38 |
Inverse problems
liu@poseidon.ecole-navale.fr
>Hello everybody, I am interested in recent bibliography in inverse >problems (1997-1998-1999) especially 3D flow calculation. Dear Vincent! Herein, I am sending some recent bibliography (and URLs) re IP (in CFD). Zhi Vang, Droegemier K. K., White L. and Navon I. M., Application of a New Adjoint Newton Algorithm to the 3-D ARPS Storm Scale Model Using Simulated Data, Monthly Weather Review, v. 125, N. 10, pp. 2460-2478, 1997 Lee, J. Kim and H.Choi, Suboptimal control of turbulent channel flow for drug reduction, J. Fluid Mech., v. 358, pp. 245-258, 1998 Thomas R. Bewley, Roger Temam, and Mohammed Ziane, A general Framework for robust control in fluid mechanics, Physica D 1998, to appear Joslin R.D. et al, Self-contained, automated methodology for optimal flow control, AIAA J., v. 35, N 5, pp. 816-824, 1997 Soemarwoto B., The Variational Method for Aerodynamic Optimization Using the Navier-Stokes Equations, ICASE Report No. 97-71, 1997. Alan Carle, Mike Fagan, Lawrence L. Green, Preliminary results from the application of Automated Adjoint Code generation to CFL3D, AIAA-98-4807 My works (2D): Alekseev A.K., On Discrepancy Gradient Calculation at Inflow Temperature Estimation from Outflow Data, Dynamical Systems Identification and Inverse problems -III, Moscow-St.P-B, May-June 1998, pp. 433-443 Alekseev A.K., Freestream Parameters Estimation Using Heat Flux Measurements, AIAA Journal, v. 35, N 7, pp. 1238-1240, (1997) http://www.me.ua.edu/3icipe/Papers.htm#Abstracts (My report at ICIPE-3). http://turbulence.ucsd.edu/~bewley/ http://www.icase.edu/library/reports/rdp/1998.html http://fmcb.larc.nasa.gov/ http://www.math.iastate.edu/gunzburg/control.html I shall appreciate any information regarding Inverse Problems in CFD (including your jobs). Sincerely Aleksey K. Alekseev senior researcher Dept. of aerodynamics and heat transfer (016), RSC "ENERGIA", Korolev (Kaliningrad), Moscow region, 141070, RUSSIA tel. 7-(095)-513-68-19 URL: http://www.infoline.ru/g23/5037/A_ALEKS.HTM E-mail: Aleksey.Alekseev@relcom.ru |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
ill posed problems: inverse heat transfer | rajeev | FLUENT | 3 | February 19, 2019 03:00 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 13:13 |
routines, inverse problems, CFD | Markus | Main CFD Forum | 0 | March 1, 2009 13:33 |
Inverse problems | vincent | Main CFD Forum | 0 | April 7, 1999 07:59 |
